Alfred.NESWADBA
en respuesta a: Anonymous
I can reproduce the issue, but (whithin just a few minutes time) I don't have an idea why the inner circles are not excluded from the 3D-Solid object after running _PRESSPULL.
Interestingly AutoCAD generated Region objects from the circles, but then they are not used at the end of the command to be subtracted.
For now, so you can continue to work: extrude the circles with a height > the previous 3D-Solid object and then use command _SUBTRACT to get the holes created.
Hopefully anyone else has an idea about the reason why _PRESSPULL fails in this situation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
