1664 Vistas, 5 Respuestas
help with presspull blend curve commands
hi when i go to use the command press pull with a completed object outline using blended curves it does not complete the presspull command correctly and certain line like circles don't get removed or added to the entity.
but when i use the presspull command will all the lines except the blend curve lines it works fine,
added example drawing of both the blend curve object outline and the normal line object outline
