11-08-2016
02:03 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-08-2016
02:03 PM
Alternatively if you have SUPERHATCH to hand you could create a rectangular full-scale block with SOLID-hatched stripes to tile your road-markings with 300 wide stripes at 30 degrees spaced 600 apart:
- draw a rectangle 300 high and (say) 2000 long
- SOLID-HATCH the rectangle.
- ARRAY the rectangle linearly to create a set of (say) 10 spaced 900 apart vertically.
- move the arrangement from (0,0) to (0,-4500)
- rotate the arrangement 30 degrees about (0,0)
- draw a rectangle from (0,0) to (1800,1039.23)
- crop to that rectangle
- erase that rectangle
- block it and SUPERHATCH
https://autocadtips1.com/2015/06/30/using-superhatch-to-make-complicated-hatch-patterns/
If you don't mind rotating the SUPERHATCH during each insertion just create a SUPERHATCH of size say 900x900 containing a 900x300 SOLID hatched rectangle.
hth,
Hugh Adamson
