11-08-2016
07:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-08-2016
07:46 AM
Probably the best way to do that with a Hatch pattern is one that has groups of closely-spaced lines, like this:
and draw it on a Layer with a color that plots in a line width that fills it in solid at the typical scale in which you would use it. Such a pattern could be defined very easily, with whatever ratio you want between the width of the groups of lines and the width of the gaps, and with whatever spacing between lines you need for the solid plotted result, and therefore whatever quantity of lines you need in each group.
Kent Cooper, AIA
