wwork
en respuesta a: Anonymous
A two command drafting solution.
Place new line using deferred Perpendicular object snap. Move new line to desired location.
  1. Invoke the LINE command
    1. Specify the PERpendicular object snap (Shift+right-click-->Perpendicular).
    2. Touch existing line (See Deferred Perpendicular cursor badge.)
    3. Click to begin new line.
    4. Specify the NONe object snap (Shift+right-click-->None).
    5. Click endpoint of new line. (This line will be perpendicular to existing line.)
  2. MOVE new line to desired location.
3. If necessary use LENGTHEN, TRIM, EXTEND or FILLET to adjust length of new line.
