Kent1Cooper
en respuesta a: Anonymous
My first thought was also that it's a lineweight issue -- the dots in that pattern [and others, and in some linetypes] are actually zero-length lines, and they are really tiny if you use too light a lineweight.  I usually change Hatch patterns with dots to a color that plots heavier than the color of their Layer, if there are also Hatches with lines in them on the same Layer, so that the dots will show up better without making the lines heavier, too.
Kent Cooper, AIA
