8656 Vistas, 3 Respuestas
Hatch won't print.
Hello!
I've been facing a weird situation for the past few days. My AutoCAD 2016 won't print the "dots" hatch. And I said print, not plot, because whenever I create the .PDF file, the hatch will show the same way I've set it to be, but whenever I actually print, it won't show.
I've also considered that it was my plotter, but I've tried to print it in several different machines and it also didn't work.
That made me consider it was a problem in my .CTB file. I've switched ctbs and it worked in a different one, just as it was supposed to be. But I need to use the original CTB, because the layers are all configured according to it. And also, the file is huge, and it's impracticable to switch all the layers.
I'm not sure if someone can tell me something other than "just create a different .CTB file", but I thought maybe this has happened to somebody else, or maybe someone thinks of something other than what I've considered already.
Help!!!
Thank you! Have a good one!
