11-01-2016
10:31 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-01-2016
10:31 AM
If you use AutoCAD2017 then Go grab the 2017.1 update (see the "point one" in the name) from your active subscription-only updates page https://manage.autodesk.com/cep/#products-services/updates
Read about it here Read about it here: http://blogs.autodesk.com/autocad/autocad-2017-fall-update/
Otherwise AutoCAD 2016 and lower were not designed for high-res monitors. It only runs on displays set to 1920x1080 (also try 2560x1440 and up to 2560x1600 if you have that option) and at 100% text scaling (no more than 125% text scaling). It will not look good on 4k displays settings on modern PCs and laptops ![]()
Read all about it here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gra...
