10-31-2016
11:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-31-2016
11:37 AM
@Anonymous wrote:
I'm a newbie with LISP. What command do I use to run it?
If you mean IsRegPoly.lsp, it doesn't define a command, but a function with an entity name as an argument. See the Usage: note in the comments at the top.
But it sounds from your prior Post like regular Polygons are not relevant to what you're trying to do, in which case that function would be of no use to you. If you're going to use it for a count to check whether someone's submission violates the quantity limit, do you need something that simply counts all closed LWPolylines? Or all of them that have no arc segments? Should "heavy" 2D and/or 3D Polylines be included?
Kent Cooper, AIA
