rkmcswain
en respuesta a: Anonymous
Tcaddy wrote:
I'm new to SSM and have an existing project that has a large number of sheets already set up.
Each sheet had its own revision number controlled by the SSM.
I can only change the revision numbers individually from the sheet set manager.
If I wanted to do a global change to the revision numbers and change them all to the same revision number, I assume that I can only do this one at a time in the SSM.
You cannot do what you want with Sheet Set Manager, however there is a great 3rd party tool (SSMPropEditor) that can do this. You’ll recover what it costs pretty quickly.
You could also do what @john.vellek suggests and remap everything to a single “SheetSet” property, but if you are going to do this, then just put your change as TEXT or MTEXT in the title block/border drawing. There is really no need for a SSM custom property for the SheetSet since the value will always be the same for every sheet.
