4617 Vistas, 6 Respuestas
10-31-2016
08:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-31-2016
08:37 AM
I'm new to SSM and have an existing project that has a large number of sheets already set up.
Each sheet had its own revision number controlled by the SSM.
I can only change the revision numbers individually from the sheet set manager.
If I wanted to do a global change to the revision numbers and change them all to the same revision number, I assume that I can only do this one at a time in the SSM. Or is there some way to apply this as a global change in one shot? I'd have to do this without breaking the original links.
I can't see any way of doing this but as I'm new to SSM I wanted to check that I've understood things right.
¡Resuelto! Ir a solución.
