john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
If your backup files and the original files are missing the information then the data was missing and the drawing written over before the crash. I suggest that you need to obtain a fresh copy from the source and then try to merge your new work into the new copy.
I did take a look at your file that you attached and ran AUDIT on it and found 47421 errors. I was also able to PURGE 22 zero-length objects, and was also able to remove 19 regapps.  After running theses commands I did see additional data appear in the drawing.
John Vellek
