Alfred.NESWADBA
en respuesta a: Anonymous
welcome @Anonymous.autodesk.com!
If the layers already have the correct color then the best first try would be to NOT use a CTB/STB. What's the result then.
Next important test: print to PDF (using the plotter "DWG to PDF.pc3") ==> does that pdf show the black color also as grey? If not you probably have less black ink in your print device?
Other option: look to the visual style of the view-port you are plotting, if it's not 2D-Wireframe then set it to "2D-Wireframe" and try plotting again.
A drawing upload would help us to support you.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
