677 Vistas, 10 Respuestas
Text from older version to newer
I open some drawings that were made on a 2012 version on my AutoCAD Architecture 2016 version and ALL text height is at least a 12% bigger.
Is there any easy way to revert this situation?
Thanks in advance!
pendean
en respuesta a: Anonymous
You forgot to move the requires custom font files from 2012 to 2016 perhaps?
Or you just need to adjust CANNOSCALE variable?
Can you fix it with PROPERTiES or in STYLE command and identify what else may be going on?
Post a DWG file, tell us what the text size is supposed to be (exactly) and where it is in your dwg file.
en respuesta a: pendean
Thanks for your fast response, pendean. Please, see attached drawing. As you will see, text is out of previous set boxes, text intersects with another text, etc.
pendean
nothing attached, please try again.
wispoxy
I see no attachment.
Do you see it now?
wispoxy
No. Use the insert file feature when posting.
pendean
Use a dropbox or google drive or one drive cloud service to share files.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I took a look at your drawing and see that much of the text is looking for a font called SPSIMP. Since it can't find it in your current AutoCAD installation it is substituting simplex.shx. If you can find this font and install it everything should go back to normal.
John Vellek
wispoxy
en respuesta a: john.vellek
Well done @john.vellek.
