1940 Vistas, 12 Respuestas
Reference Manager
I tried adding a drawing in Reference Manager and received an Alert box that said "Drawings not added because of problems: 1". Does anyone know what this tremendously informative message might refer to. The drawing is not open and is not read only. ALI Asghar
Alfred.NESWADBA
en respuesta a: Anonymous
can you open the drawing with AutoCAD? If so, run command _AUDIT to check the internal database, save the dwg, close the dwg and try the reference manger again.
if that does not work, can you please create a screenshot from that message and show it to us?
BTW: does that happen with all DWG-files you have or just one specific file?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Dear
Yes i can open that file with autocad , in some file's working reference
manger but in some file's not working. i send you screen shoot ( i already
open file with recovery and audit that file but still reference manger not
working.
Best regards,
Ali Asghar
Thales Group
Alfred.NESWADBA
Nothing attached.
By any chance: are the files you can open created with an older DWG-format (older AutoCAD release) and the other files are from a newer AutoCAD? In that case verify that you open the reference manager from the newest AutoCAD you do have installed.
- alfred -
Alfred NESWADBA
Dear,
same format file..
Alfred.NESWADBA
can you please provide a screenshot from that message? (so we can see the details about the message as well as the state of the reference manager)
- alfred -
Alfred NESWADBA
[image: Inline images 1]
Alfred.NESWADBA
please look to the forum, your image is not attached.
Please use the "reply" button in the forum instead of answering by the mail system.
- alfred -
Alfred NESWADBA
Please Check this file
 best regards,
Ali Asghar
Alfred.NESWADBA
No file attached, but would be good to see what is inside the file.
- alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Please attach the file(s) so I can take a look for you.
In the mean time, remove the xref if it is already part of your drawing and then reattach it.
John Vellek
jjohnson
en respuesta a: john.vellek
I know this is an old post but the problem I found out that exact error message was fixed by only adding first level xrefs.  I made the mistake of letting it try to find nested xrefs no matter the level and it never worked.  Closed reference manager and changed that setting and it works fine now.
