2372 Vistas, 13 Respuestas
Is there way to apply a layer's properties to an object?
I am trying to create a legend for all the objects and linetypes in a drawing but want all the items to be on a single layer. Currently I have to manually apply the properties of the layer (color, lineweight, linetype, etc...) to the object so that they will plot the same.
I know the "setbylayer" command will strip all the objects properties and set them to bylayer, I want something kind of like the opposite.
If I use the "match properties" command it applies all the selected objects properties, but they are always "bylayer" I need something that gets the layers properties and applies it to the object.
I hope this makes sense, and thanks for any insight.
Mike
