braudpat
en respuesta a: Anonymous
Hello
If I remember well, you can use a field with the VOLUME property which is NOT available !
So you Will use for example thé AREA property, copy /paste expression to the Notepad.exe, replace AREA with VOLUME, copy /paste expression again to a NEW MText...
Then with à Formula based on the VOLUME + Density,  you Will get Mas...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
