1742 Vistas, 7 Respuestas
Write Mass Properties to MText
Is there a way to write the value from Mass Properties to MText or an Attribute?
What I would like to do is have mass properties calculate the volume of a 3D solid and at a minimum display the cubic inches in a text string. Ultimately I would like to use this value to calculate the material weight of a 3D object.
Does anyone know an out-of-box solution?
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
The only way I have ever been able to do this is by running MASSPROP and saving the results to an MPR file. Then I open that file in notepad, copy, and then paste into Mtext in AutoCAD.
This can be a lot of steps. Perhaps a post in the Customization Forum will give you a better solution.
John Vellek
vladimir_michl
Not out-of-the-box but you can use fVolume or fArea>Object (free) to make a dynamic field reflecting the object's volume. See
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4861
http://www.cadforum.cz/cadforum_en/dynamically-display-any-object-property-as-a-field-tip9482
Vladimir Michl, www.cadstudio.cz
braudpat
Hello
If I remember well, you can use a field with the VOLUME property which is NOT available !
So you Will use for example thé AREA property, copy /paste expression to the Notepad.exe, replace AREA with VOLUME, copy /paste expression again to a NEW MText...
Then with à Formula based on the VOLUME + Density,  you Will get Mas...
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
wispoxy
Hello @Anonymous,
Might be easier having a field linking to an excel cell that has the equal value needed. With excel you should be able to setup a formula as @braudpat mentioned.
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
john.vellek
Hi @Anonymous,
Did you get an answer that fit your workflow in this thread? Please post your status.
John Vellek
en respuesta a: john.vellek
I used a variation of this; utilizing excel to display multiple values and run my formula for weight. My issue is still running this through another program, but I can work around for now. I am looking at lisp routines for a solution that will output to text directly in autocad.
Thank you for your suggestion and help.
