556 Vistas, 5 Respuestas
Counting blocks in blocks
Hi .
I am working as a storedesigner and need a special thing. I need to count the total amount of blocks ( parts ) in a drawing. That i it self is no problem with Bcount command .
But !
I need to assamble blocks of multiple other blocks and make that block dynamic. Otherwise it takes forever to draw a full store.
But i need to count these first blocks . Is it possible in Autocad ? I know Archicad can do it  :cara_con_una_leve_sonrisa:
For example - One store section is bulit by  - 2 wall brackets, 4 Deep shelves , and 4 back plates . These items together needs to be "one" dynamic wall section block that just multiplies when i drag it . How can I find the total amount of backplates needed when i`m done with a whole store.  ?
imadHabash
en respuesta a: Anonymous
i suggest to use QSELECT command.
Imad Habash
Darin.Green
This is definitely possible with a lisp routine... Take a peek <<here>> for more information and report back.
If this information was helpful, please consider using the Accept Solution
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
I suggest that you try data extraction. Here is a prior post that describes something sort of similar. You will find a drawing attached at the bottom too that you can try.
Please let me know if you have more questions on this. You can even attach a sample drawing and I can prepare a video of the steps for you.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
en respuesta a: john.vellek
Ha ! Awesome .
I just use command "dataextraction" and it works just like i needed it to .
Thanks for your help. Everything is so easy when  you know how to do it . :cara_con_una_leve_sonrisa:
