- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Open different DWG files in the same AutoCAD2015
I'm trying to open different DWG files and it is always opened in a new AutoCAD software and not in the same I had previously opened with different tap.
I don't know why I can't use Autocad DWG launcher to open each file.
AutoCAD 2015 is installed in G: and not partition C: where files are. I'm not sure if this can be the problem.
Thanks in advance.
Jaume
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i suggest to change your SDI to zero.
ommand: sdi
Enter new value for SDI <0>:
try it.. ![]()
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Suggestion 1: Use the OPEN command in AutoCAD to open DWG files
Suggestion 2: rather than click on a dwg name in Explorer, drag the file to either the AutoCAD desktop icon (to open in a new session) or onto the AutoCAD command line (to open as a new dwg in the current session)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Jaume,
Did the solutions in this thread help to resolve the file open issue? If so, please mark the post or posts that helped you. If not, please update your status.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
One thing you can do is to remove the filetype association for opening .DWG files when double-clicking in something like Windows Explorer. It will vary somewhat with your operating system, but you should be able to right-click on a file name, choose Open with and possibly go a level further down with something like Choose default program, and un-check the button that says something like "Always use the selected program to open this kind of file." Then, with no program associated with .DWG files, every time you double-click on one, it should ask you what program you want to open it with, and you can choose the version of AutoCAD you want to use -- make sure that "Always use..." button is un-checked every time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your help.
I had to re-install AutoCAD in the same particion C where the files are.
