Alfred.NESWADBA
en respuesta a: Anonymous
when you start _RENDER do you see that message:
This message shows me that you have not run the -DWGUNITS command to the end (where it asks to match INSUNITS with these current set units).
But that was only the start of a bit longer way to go.
Next is the size of the mapping, I take the material "Cherry(2)" as sample, you might have to correct more than just this one material:
Looking to the image definition there is a texture mapping defined based on an image, that image is defined to be 1x1 (which means the mapped image with your units = 1inch x 1inch in size). Take that image and place it 200 times onto the table ... you won's see any structure of the image, it's much too small!
Next is the lightning: you have not placed a manual light, but turned on the sun-light (which makes all much to light).
Turn the sun-light off, this brings you back to a default lightning and ... look to that result:
In AutoCAD model-space:
That's the point to start now with a closed scene (no light-rays can exit a closed scene), with light (inside stay with point or spotlights, outside you can use sun and sky)
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
