Alfred.NESWADBA
en respuesta a: Anonymous
most usual for that situations is the fact, that units set to the drawing do not match to your geometry size.
Make sure that the setting in -DWGUNITS is correct.
If not then upload a drawing with one of your wooden objects so we can take a look into it.
If you defined your own material with mapping images then please use command _ETRANSMIT to make sure we get all the data.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
