5933 Vistas, 17 Respuestas
pdf import only importing text
I used pdfimport the other day and it worked great. Now with a new file, the only content that seems to be correctly imported is the text. I will say that when I highlight a line in the pdf and "bring to front" it exports correctly. However, I can't determine a reasonable way to highlight only the lines in the pdf. Furthermore, adobe continues to crash if I highlight so much as a box and try to bring it to the front. There are 2 layers in the pdf and as far as I can tell, they have the exact same content. One is 'layername-las', while the other just 'layername'
Attached you will find the current selected options when importing along with a converted pdf-dwg showing only txt. The apparent line is the "brought to front" line.
What is the correct way to import this vectors in this file?
