ScottHodges
en respuesta a: Anonymous
If you are putting your border in modelspace, it must be scaled, NOT your objects. If you are putting dimensions in modelspace then the dimscale should set the size of dimensions. Text objects in modelspace should be scaled the same factor. All objects in a drawing should not be scaled but drawn true size. Any other approach leads to many problems. As others have suggested it may be preferable to place your border in the layout
