john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Block substitution is easy and can be done at the command line which makes it useful for a macro.
I made a quick video that might help you with the process.
I make a drawing that has my block. I define a new block that I want to change it to. I wblock it out and then rename it (I do this just so I can keep track of what it is called).
Then in the drawing Ii use -Insert, blockname=blockname
Lastly, I use ATTSYNC (or BATTMAN) to update the attribute.
John Vellek
