- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, again!
Using blocks works better than xrefs in terms of regenerating the fields. With blocks i can change for example the name of the project without opening the drawing (this is what i am aiming at). The only problem that pressists is with block replacement from one to another drawing.
Here is small example:
- I've put my block in the first drawing modified some attributes as i need them and they work fine, then i copied it to the other 2 layouts and everything is fine
- but after a while someone wants from us to add another designer in place which he wants it to be and we add it in the block of drawing1 but how to replace it as fast as i can in the other 2 layouts (and if there are 20-30 layouts i would like to batch replace in all the drawings)
@john.vellek Thank you for your answer.I assume this is what you are suggesting but i coudn't understand how to replace block from one drawing to another (the only way i can think of is to delete old block and replace it with new, or to copy new one with new name and then replace it). Ways i find are very time consuming and i would need to open all the layouts one after another to replace blocks.
@cadwomen Thank you for your the answer, but i didn't understand what you suggest can you give me an example please.
