en respuesta a: john.vellek
@john.vellek thank you again for the reply!
I am using reference because i need one title table for all my sheets, for example if i need to add new field i just add it in reference and i dont need to copy and paste it in all the drawings (if it is a block i would need to replace old with the new one). That is needed because we are having different title table with every project and we often need to add or delete some information from it and redesign it in the process of desining (usually near the deadline)
Is there a way to assign block(or something like block or xref) in sheet set which can be edited once and refreshed in all the layouts?
That works great! I am usually using defaut page setup and with every plotting am selecting my plotter, plot area, scale and ctb. file but if i assign those things in the begining it is working as i wanted. Thanks!
We are saving files to 2004 because some of my colegues use old versions and they can't view 2013 format.. The only problem i've seen is that files are bigger in sizes.
