- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I am curious why you don't assign these properties directly in the sheet set so you don't need this xreference? Your fields can then be directly part of your titleblock and can obtain the custom properties on a sheet or sheetset basis.
While I am doing that I want to address the second question you asked. I suggest that you assign a page setup to each layout that you want to publish. That way when you have multiple drawings you can select the "Use Plotter Named in Page Setup" option.
BTW, you are saving these files in a very old file format (2004). Do they behave differently for you if you save them in the current 2013 format?
John Vellek
