john.vellek
en respuesta a: Neilw_05
Hi @Neilw_05,
I am glad you like it. It worked so well for me in the past I removed all layers from our templates entirely!
1)  At any rate, I just copy pasted your layer info into the spreadsheet one item at a time to make sure the example came in clean for you. There are a variety of lisp routines that might automate this for you. (Check out the Autodesk App Store perhaps?) You can even just use the old-fashioned -layer ? * at the command line and then grab everything off the text screen but that requires a bit of editing.
2)  The no-plot layers are hard-coded into the lisp routine. I can help you with this if the rest of it works ok.
3) The beauty of this routine is that it will actually reset the layers even if they already exist! It will not remove layers but it will create them and set all the properties to what you have in the CSV files.
John Vellek
