- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Profile doesn't have much to do with the UI, aside from specifying the Main and Enterprise CUIx files. In most cases UI problems, like toolbars not being shown, minimal menu dropdowns, etc. are simply a matter of not having the correct Main CUIx file set up - they've done a MENULOAD or some such fiddling around, and any changes to the workspace have been saved to some different CUIx file. Since you can only save workspace changes to the Main, its a good idea to know exactly which file that is/should be.
Most of our "missing toolbar/menu/etc." problems are related to users trying to manually MENULOAD or fiddling with the CUI files (without bothering to understand what it is they are doing). Some simple automation to set those will always keep the workspaces in the right location.
