dgorsman
en respuesta a: Anonymous
AutoCAD itself doesn't do much with the internet.  There's a couple of options to consider.  Do you have CIP enabled?  Are you using an older perpetual stand-alone license or a Desktop/rental-model license (although the latter shouldn't matter too much - license service is very low requirement and is intermittent).
Outside of AutoCAD there's a few things to consider.  Are you signing in to A360 by default?  Are you using it to actively synch drawings and/or settings?
Then there's the various Application Manager/Desktop manager/etc. utilities which check for downloads.  Those can be turned off, you generally want to be checking/applying updates in an organized manner rather than on-the-go.  Definitely want to be downloading program updates on a hard line...
