- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
In order to attach a file, you might put it in a ZIP file first.
At any rate, it appears that you are drawing everything in Modelspace. I suggest that you draw your model in modelspace. Then, select a layout to switch to paperspace. This is where I suggest you place your titleblock/border. Then using Mveiw, create a viewport so you can see your model. Now you can set the scale for the viewport to maximize the view of your model.
Lastly, you can dimension directly in paperspace if you like of you can do so in modelspace too.
Please let me know if you have questions on any of these steps. I prepared a video of how my suggestions would work for you.
John Vellek
