- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
How do I change the units so when I type a line length it will be in millimeters
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Dear Mr.Acs
In command window, type "UNITS" and choose the insertion scale you want from the drop down dialogue box.
Hope this might have helped you..
Regards
Di****h
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
select your needs from DDUNITS command dialog then start your drawing with millimeter inputs.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Welcome to the Autodesk Community!
To adjust your units, try using -dwgunits and units. Here is an AKN Article that describes how units work in AutoCAD.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem or if you need additional information and resources.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
