john.vellek
en respuesta a: Anonymous
HI @Anonymous
@Anonymous wrote:
I want to dimension in viewports in paper space and not have those dimensions show up in model space. At the same time I do not want the borders of the paper space viewports to print out. I want the dimensions in the paper space viewports to "follow" the objects in the viewport as I pan the objects around for fit in the viewport. Can't seem to get all that with what I am doing now. I dimension in the viewport and it shows up in the model whether I want it to or not. If I dimension in paper space only, the dimensions to not "follow" when I pan the objects in the viewport. Seems like I am doing something wrong and this should be a common practice with a simple fix, but I have been all over the dimensioning features (I think) of 2014 and still have not cracked the code.
To have dimensions not show up in modelspace they have to be drawn in paperspace but they will not shop up in the correct location if you move your model
You could draw them in modelspace but you cannot override the visibility to thaw it only in the viewport.
You might consider working in a base file and then xrefing it into a"master" file where you could add the dimensions in modelspace there. You will still have to make sure that if the model moves in the original file that you adjust the dimensions in the "master" file too.
John Vellek
