john.vellek
en respuesta a: Anonymous
HI @Anonymous,
It sounds like you have gotten part way through getting this to work by getting the menus to load. However, it does not appear to actually have a path to its addins or the path has not been added to the Trusted paths.
I would suggest contacting the manufacturer to verify that 1) this plugin is compatible with AutoCAD 2017, 2) that you have gone through the correct steps to install the software, and 3) have them isolate the issue in why it is not running properly.
Since I can't install this on my side I can only be of limited help.
John Vellek
