- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
not sure to understand all your things you are doing. But reading that you copy geometry between drawings and there between details/layouts to other files (and so getting troubles with scales, blocknames, ...) I see the problem more in data organisation than in the handling AutoCAD does handle that.
I would think about not to copy data between drawing, use XRef's instead .. with this simple change you get rid of all your blocknames (which are critical when copying data between files having all a block defined with the same name.
I would think about details ... don't create different files for details of one base object. You never get them all corrected when the base geometry changes. Use layouts to display one object in different scales, that's it. So you have to send the customer one file and he has all together, it does not make sense to send multiple files as you are never sure to have all up-to-date.
>> For each sheet, I save multiple Autocad files using the 1:1 feature, but for each one I have to select a different base scale
>> Say I have a Solidworks drawing sheet with 3 views at 1:16 and 2 views 1:2 and 5 views 1:1 scale, I will save 3 ACAD files
I would take the original geometry, not the views. Views are just results of different viewpoints, details, sections, ... from the original object. The base object has all you need I guess.
Just my 2c, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Agreed, this is not a problem with the software but rather in the process.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You should consider new techniques in organizing your CAD work and drawing file structures. Layouts and viewports are a good beginning. Annotation scales would help you maintain consistency in your drawings/s. If your in a shop where many standardized parts are designed-into projects then maybe a great template with blocks already embedded would be better than XREF.
Good Luck
