- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
This problem occurs when you use some models of Logitech® mouse [like my M560], that changes the regular escrow to smoot mode when you press the wheel.
The way I find to solve it in Revit® and CAD® was use the command “PAN” at the keyboard, and them use the left bouton to pan. Otherwise, I use also my old M280 mouse in such programs, due it don´t have the dual mode wheel.
There is the only way to solve your problem. That´s all my friend. Thanks TOM.
@Anonymous wrote:Whenever I use the middle button to pan, it switches between open tabs. For example, If I have a file open and the Start Tab is beside it, when I click and hold the middle button to pan in my file, it switches to the Start Tab. I am using a Logitech M560 Mouse. Before you ask, Yes, I did download the appropriate mouse software and programmed the middle button to be used in this fashion. I was using the function fine for several weeks up until this morning when I opened AutoCAD and this issue started. I am using AutoCAD 2017 Student.
