- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I downloaded an autocad plugin from the Daikin website (Ihttp://www.daikin.co.uk/contacts-and-downloads/software-downloads/air-conditioning/index.jsp) called VRVCad 2D which should help simplify air conditioning design. I installed it and the files went into C:\users\appdata\roaming/autodesk\applicationplugins, however it was not showing up on the ribbon/menu bar as shown in the tutorial guide. After doing some research I concluded that I probably had to load it manually so I used the CUILoad command and found the Cuix file within the VRVcad.bundle folder and loaded it.
It now appears on the ribbon/menu bar but when I try to use any feature of the plugin it says "unknown command".
I'll greatly appreciate if someone will assist me. I am using autocad 2017
Thank you.
¡Resuelto! Ir a solución.
