09-16-2016
12:40 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-16-2016
12:40 AM
>> However the drawing is subject to NDA so I can't upload it
Open your drawing, create a new drawing parallel to it, use copy & paste to get the critical object to the new drawing.
If that works then you can copy all your geometry to a new drawing to get it "healed".
If that shows the same issue (and it's just a simple text) you can upload this new drawing as it does not contain critical things ![]()
Always worth to try:
run command _AUDIT, see if it finds errors in the drawings database, if so repair them, close and reopen the drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
