- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Zoom object zooming out too far
Folks hope you can help.
I've downloaded an eval of 2017. I haven't needed to use CAD since R14 (that's R14 not 2014 BTW)
Anyway I'm using Zoom Object and it's not working as described.
If I select an object (piece of text for example) and then Zoom Object instead of zooming in on that object and filling the display I'm roughly over the object and have a window width of 950m approx.
It doesn't matter what object is selected.
Any clues?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
welcome @Anonymous.autodesk.com!
Restart AutoCAD, create a new drawing, draw just one line (0,0 to 10,10), then again run _ZOOM _OBJECT and select that line ... same issue?
If not (what I expect) it seems to be drawing specific, therefor please upload the drawing where this happens and mark the object that has that problem.
Standard questions:
- you do have installed the latest AutoCAD service packs?
- you do have tried that with disabled hardware acceleration (command _GRAPHICSCONFIG)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are correct. A new drawing doesn't exhibit this issue.
However the drawing is subject to NDA so I can't upload it. BTW all objects exhibit this issue described, no matter what. Block, text, polyline etc.
I will check for service packs and disable hardware acceleration to see if they have any affect.
regards
Andrew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Open your drawing, create a new drawing parallel to it, use copy & paste to get the critical object to the new drawing.
If that works then you can copy all your geometry to a new drawing to get it "healed".
If that shows the same issue (and it's just a simple text) you can upload this new drawing as it does not contain critical things ![]()
Always worth to try:
run command _AUDIT, see if it finds errors in the drawings database, if so repair them, close and reopen the drawing.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
An audit showed one minor issue.
Service pack and hardware acceleration showed no change.
I will try the copy and paste into a new to see if that works.
Thanks for the assistance.
Andrew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi awilliams55ZY3,
Follow the below mentioned.
1) Apply the command UCS => World and then PLAN => Current.
2) Select all object by using (Ctrl.+A) and deselect the required design by using "Shift" key and press the 'Delete' key
Hope it work
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks folks however, I'm calling it.
The drawing is too poisoned to function.
All suggestions provided had nil effect.
I tried -EXPORTTOAUTOCAD or AECTOACAD as there were Proxy objects to see if that was the problem but to no avail.
I suppose I could go element by element and layer by layer but there are too many drawings for this to be viable.
Zoom object works but not for my drawings.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for the continued interest but no I can't supply the CAD files, the drawings are subject to a Non-disclosure agreement.
regards
Andrew
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I had the same issue which i fixed by lowering down the scale of all the objects. My original scale was 1000x times bigger than usual, so i lowered it down to 1/1000 and now the zoom-object works properly. Hope this can help.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You should always draw everything at 1:1. Never draw anything at a scale. It only causes problems and confusion.
Nick DiPietro
Cad Manager/Monkey
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Worked perfectly, thanks!
@kite15 wrote:
Hi awilliams55ZY3,
Hope it work
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I FOUND A SOLUTION TO THIS:
USE UCS COMMAND: TYPE 'V' FOR VIEW, AND HIT ENTER
THEN TYPE 'PLAN' COMMAND: THEN TYPE 'W' FOR WORLD, AND HIT ENTER.
ZOOM SHOULD NOW WORK NORMALLY WHEN YOU ZOOM ON OBJECTS.
