- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
OLD depending on the context is referring to either our old company template, old blocks or text styles. These were when we were annotating our drawings in model space using annotative text and dims. CURRENT is our new template that we are now using, NEW is referring to our new blocks and text styles.
Old files/blocks= 1 Siefert Assoc.Eng.[old].dwt, Attributes[old].dwg
New files/blocks= SA_09.07.16[current].dwt, Symbols and Attributes[new].dwg
SA-Text (Century Gothic) and SA-Draft.Stamp (Arial Black) are our new text styles. Siefert and Siefert_Annotation (Century Gothic) were the primary old ones, all others are also old and no longer used.
Interesting thing one of our guys came across, if you drag in the entire file that the block is in from the design center into the file you are working in, then INSERT the block you need it displays like it should. I think we narrowed it down to that the new SA-Text text style is not following the block when dragged from the design center. In one of the tests I ran I tried to bring in just the new text style into a stock ACAD template and it won't load. Command line read "Textstyle(s) added. Duplicate definitions will be ignored" However even if the text style is already in the file the STANDARD text style is used. The drag the whole file workaround is ok for now, there aren't that many blocks in the file and most of them are very commonly used. Really want to get this fixed though, I'm sure this will deter future blocks from being made/updated.
Oh, not sure if it makes a difference, we are running ACAD & ACADLT 2016 with SP1. It happens for both.
