en respuesta a: Anonymous
Well I guess it wasn't the problem as it's still happening. We had a couple of guys trying and testing things but they weren't communicating and doing it here and there. I'm thinking that weren't being effective so I ran my own tests and documented everything. Basically dragging a new block into any template from the design center, will not display properly; weather the text style is imported or not varies. Using the old blocks works, every time.
The company did a major switch to annotating everything in model space with annotative text/dims to paper space. We are getting into more 3D work and paper space annotation is almost required to make life easy. The company template and annotation blocks were revised to accommodate this change. Since that change we stared having problems.
At this point we don't know if it's the new block, new template, new text style or something else. I have attached the files I used for testing as well as my test notes.
