Alfred.NESWADBA
en respuesta a: Anonymous
in case of a missing SHX you should get a warning at the moment you load a drawing and AutoCAD can't find the SHX file (as long as you didn't block that message).
Another trial is to disable the hardware acceleration, as now (with AutoCAD 2017) the gc is responsible for showing the line-type ... and there were some cases were that failed (command _GRAPHICSCONFIG).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
