1244 Vistas, 6 Respuestas
AUTOCAD 2016 FATAL ERROR
WHILE I WAS TRYING TO INSTALL AUTOCAD 2016 MY PC SHUTDOWN . AND WHEN I RESTARTED PC  N TRYED TO START APP IT WOULDNT START, SO I UN- AND TRYED TO REINSTALL THE  PROGRAM. BUT NOW POP-UP MESS. POPZ UP SAY'N AUTOCAD 2016 COULD NOT BE FOUND ON THIS COMPUTER, TO FIX REINSTALL AUTOCAD 2016 ... SO I TRYED N RETRYED, N THEN THOUGHT,   I AM REINSTALL WITH A FRESH DOWNLOAD... THE PROBLEM SHOULDN'T AND IS A BIG INCONVENANCE.... IF ANYBODY HAS A VAID WAY TO FIX THIS , PLEASE SHARE....
Etiquetas (1)
jasmin.gonzalez
en respuesta a: Anonymous
Hi @Anonymous and welcome to Autodesk Community!
Sorry about the issue you are having.
I escalated your issue to our product support team on case 12147327 and they will be contacting you directly through the case.
Thank you for your patience.
Jasmin Gonzalez
john.vellek
Hi @Anonymous,
Welcome to the Community!
I am sorry that you are having problems installing AutoCAD 2016.
  • I suggest that first, you perform a clean uninstall per this AKN Article
  • Then I suggest re-downloading the application installer using the Virtual Agent
  • Please also review this post regarding Best Practices to minimize problems during your installation.
John Vellek
john.vellek
Hi @Anonymous,
I am following up with you to see if you were indeed able to get your product installed and running properly. Plesae update your status.
John Vellek
en respuesta a: john.vellek
not yet...i gave up...i got autocad 2017. but need 2016 for advance steel,
n concret.....thankz doe
john.vellek
Hi @Anonymous,
I suggest that you consider going through the steps in my prior post. I need to say though if you have 2017 installed, you will not likely be able to reinstall 2016 without first removing 2017.
Advanced Steel is also available in a 2017 version should that be the easier route.
John Vellek
yea thank ive thought bout uninstall of 2017 but didnt wanta go though process agin....n i cant find advance steel or concret in the rite kind of download...only the brown installers which my pc wont install
