- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I played with this concept a bit and I am convinced that even if the layers get included in your PDF, they are not likely to perform the way you think.
For instance, I created a model with parts on three layers. If I set the Visualization style to 2d Wireframe, I do indeed get all the layers when I plot to a pdf. In the PDF I can toggle on and off the layers and the wireframe model also behaves correctly.
If, however, I set the viewport to any other visualization style, I only end up with one layer (my viewport layer). Even if I merge the two PDFs I cannot control the individual parts of the model by using layers.
I believe that when the visualization is set to anything other than 2D wireframe, it is treated as a single object (as if it were rendered).
John Vellek
