664 Vistas, 3 Respuestas
Plot with layers in pdf
Want to plot shadeplot hidden and with layers.
If I plot with legacy hidden only the layers in paperspace plot... well, and one random layer in model space.
If I plot with as displayed I get all of the layers.
When I open a pdf, I want to still be able to turn layers off and on in the pdf format with shadeplot hidden.
I am fairly experienced, so if lisp routines or Macros fix this I will possibly understand.  Any fixes are welcome.
Autodesk Building Design Suite Premium 2014
Fabrication CADmep 2014
pendean
en respuesta a: Anonymous
hidden = hide stuff. Right?
show us a DWG file with the issue, let's make sure we are all talking about the same things first.
john.vellek
Hi @Anonymous,
I played with this concept a bit and I am convinced that even if the layers get included in your PDF, they are not likely to perform the way you think.
For instance, I created a model with parts on three layers. If I set the Visualization style to 2d Wireframe, I do indeed get all the layers when I plot to a pdf. In the PDF I can toggle on and off the layers and the wireframe model also behaves correctly.
If, however, I set the viewport to any other visualization style, I only end up with one layer (my viewport layer). Even if I merge the two PDFs  I cannot control the individual parts of the model by using layers.
I believe that when the visualization is set to anything other than 2D wireframe, it is treated as a single object (as if it were rendered).
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
