1519 Vistas, 4 Respuestas
Underline Attribute Text
I have created a block for Room Labels that has room for two lines of text (LINE1 and LINE2) with the room number under line 2. I want the text on LINE2 to always be underlined without have to place the %%U in front of the text. I have found that as you enter the text for the room name, if you do not pay attention, you will delete the %%U that you can set as the default text.
Thanks in advance!
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I am not sure of a built-in way to accommodate the line in your attribute in any other fashion. However, if your Room Number is a fixed number of characters and that is what you want to underline, perhaps you could just include a line in the block that does this.
John Vellek
john.vellek
Hi @Anonymous,
Is it possible to attach a sample of what you are working on with the attributes? I would like to see if I can give you some more suggestions on how to make this work better.
John Vellek
en respuesta a: john.vellek
Please see attahced
john.vellek
Hi @Anonymous,
I took a look at your block. As I mentioned previously, if the numbers are always a fixed number such as four characters, then simply drawing a line and making it part of your block is probably the easiest way to accommodate your request.
As an alternative, i tried putting in a Field that was linked to the Room Number. Unfortunately I could not get it to update properly.  I suspect though, that in the customization forum you will find someone with a nice way to get this to work.
John Vellek
