imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoDesk Forum,
you have to prepare your plotting settings from PAGESETUP command in the Layout then and when you finish all of your settings ( see attached image) Set it to current and it will be as you need.
@Anonymous wrote ( ... because I want to make sure i'm plotting correctly. )  all what you have to do is to attache you sheet frame (A3) to the
layout then make your VP in proper way. NOW for plotting you can follow the :
- after Crtl+p a dialoge will appear go and select from Page Setup your already prepared settings.
- forget all the previous steps and Ctrl+p prepare your settings and plot.
Note:
you have to make sure that the scale is proper with your drawings and VP.
- you can control all Layout elements from options \ Display \ Layout elements.
Imad Habash
