09-06-2016
03:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-06-2016
03:34 AM
Here is step by step information on How To Set Geographic Location from a Map
Here is information on how you can capture a Rectangular Area of the Online Map
Please note that you need to be signed into Autodesk 360 in order to use the Online Map Function.
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
