- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi There,
Are you talking about simply adding an image in AutoCAD with its original image size attributes(dimensions)?
OR are you looking to place an image in AutoCAD from a Map with a specific Geo Location?
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here is step by step information on How To Set Geographic Location from a Map
Here is information on how you can capture a Rectangular Area of the Online Map
Please note that you need to be signed into Autodesk 360 in order to use the Online Map Function.
Rudi Roux
LinkedIn
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi there,
If you found that my previous post resolved your issue/query, please mark it as a solution so that others could benefit from it in the future.
Rudi Roux
LinkedIn
